Salta al contenuto principale
Guide di riparazione e informazioni per il disassemblaggio per i laptop prodotti da ASUS.
2525 Domande Visualizza tutte
Computer can't get past BIOS, and doesn't have any boot options.
I don't know what version of ASUS I have, but it is relatively new, a few months ago my computer started booting in BIOS, but I thought nothing of it as I could still boot just fine, just had to press escape to boot, but a few weeks ago my computer wouldn't boot when I pressed escape, there is also no installed storage drive, as well as no boot options in the boot menu, and the boot priority list is blank. I tried to find fixes myself, but didn't find any because I don't know what version my ASUS is, if you could please help me that would be great.
Questa è una buona domanda?
Punteggio 8
4 Commenti
I have Asus M515D, straight from the shop.
I have no CSM option, disabled both Fast Boot and Secure Boot Control but no CSM. Also under Boot menu there is nothing listed. Can’t do anything. Is there a faulty disk? Disk is nVme.
da
@razorboy001
Have you tried booting from a bootable USB flashdrive just to prove that boot manager is working?
If it is straight from the shop is it new or under warranty etc or has it just been repaired? In either case take it back.
da
I have never personally seen a bios not show all the different screens completely except for once when the laptop was actually hanging up when loading all of the screens. I don’t know how long you waited every time you booted this up but I just thought this could be a possibility. Just throwing that out there.
da
Solved it with an old USB external CD/DVD read/writer...
da
Aggiungi un commento
6 Risposte
Soluzione Prescelta
From what you have said and assuming that the hard drive is still in the computer and there have been no attempts to open the computer or remove the drive it could be a hard drive failure. That would then not report to a system post the hard drive as available.
Is the laptop still able to get to the BIOS ? if I have understood you right I would personally use a bootable USB drive and set the BIOS to allow to boot from USB. if that will boot for you then it could well be a simple case of a replacement hard drive
You can download the tools to either make a USB boot drive drive from a USB or download the image of one and use that to create it but either way its very simple and lots of tutorials online you can find using a search engine
Punteggio 3
4 Commenti:
Ok, so if I'm understanding you, I should essentially load windows onto a flash drive and boot from that? And the only possible problem is a bad hard drive? Also, to answer your question, yes it does boot to BIOS.
da
Any bootable USB does not need to be windows just a bootable USB for anything if it loads without an issue it would point to a failed internal hard drive so then replace the hard drive and reinstall windows and problem sorted
da
Hi @ Gustavo,
Knowing the full model number would be helpful. Is there nothing written in BIOS or on the case to tell what the model is? Also what OS was installed and working before?
It may be that you cannot boot using a USB if the boot options are not showing. It may not look at the USB to boot from if the boot order is missing The HDD may have been the only enabled option for example
da
But in a situation whereby the hard drive is completely removed and the system still boot to bios. All of the above solution have been tried, thanks for all your advice, but the system still boot to bios. Whàt next?
da
Risposta Più Utile
  1. In Boot Menu -> Change FastStart to [Disable]
  2. In Security Menu -> Change Secure Boot to [Disable]
  3. Then 'Save Configuration & Exit', when the BIOS screen appears again
  4. Go to the Boot Menu again -> Change Launch CSM to [Enable]
Punteggio 48
26 Commenti:
Thanks, it saved my time.
da
Thank you for this, tried every post until I got this one.
da
The CMS to (Enabled) was my problem
da
you sir, are a godsend.
da
Men, you save my life!
da
Mostra altri 21 commenti
I found that some PCs will not boot off a USB drive. some examples, most windows XP machines, older macs, I'd say use a windows installation disk as in BIOS the order is always defaulted to Cd drive first, HDD second. makes it so non technical users dont have to mess with the BIOS and just pop in the windows CD.
Punteggio 1
Hi, Did you find a solution to this problem? I had similar problem and this worked for me. https://doneryt.blogspot.com/2018/12/asu...
Punteggio 1
1 Commento:
this worked for me.. thanks
da
Change it to Legacy boot and move the internal drive up in the Bio settings.
Punteggio 0
7 Commenti:
So I’m having an issue that seems similar but not. Loaded windows 11, now it starts at the asus logo screen but immediately switches to the Aptio setup utility. I’m concerned bc under the boot tab it literally says:
Fast Boot [Enabled]
Boot Option Priorities
Delete Boot option
And nothing else. Please tell me there is a way to fix this. It looks like all the boot options are just gone.
da
@T B Disable fast boot
da
Did that but doesn't work
da
@T B did it work?
da
@Ryan Jacob Alright try Boot Option Priorities and tell me what it says.
da
Mostra altri 2 commenti
I have an asus rog strix scar. No devices in the bootable drives menu, but it does recognize my 1tb ssd. I tried using a usb windows 11 bootable drive but it leads me to error screens. Never seen a device that won't let me use a bootable usb drive. Any ideas why it doesn't want to boot up and install windows on my main ssd?
Punteggio 0
1 Commento:
Shane I’m having similar issues just picked up a b550 rog gaming mobo and legit it wouldn’t install windows 11 then got 10 to work but seen I’ve some how installed in a legacy bios because my ssd I bought the to go wit my new mobo WD850 and said windows wouldn’t install on what ever my ssd was formated as idk did some $@$* got windows to install seen it’s legacy then I got it set up game a bit next day fire pc up no windows or boot drive found a solotjon not sure if it’s the best but also not sure if I should be getting windows installed as uefi not legacy’s idk
da
Aggiungi la tua risposta
Gustavo Dickington sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 56
Ultimi 7 Giorni: 424
Ultimi 30 Giorni: 2,083
Tutti i Tempi: 134,485
