Using Suction Cup to remove screen with a screen protector
Can you still use the suction cup to lift up the screen if you have a glass screen protector (ZAGG) installed on the screen or will it lift off the protector?
Questa è una buona domanda?
You can use suction cups no problem but on cracked screens the glass tends to separate from the palstic frame if it is an after market screen.
I always use razor blade on sides of screen to lift it up after taking out the two pentalobe screws.
Brian, you can use a suction cup to remove the screen. The screen protector won't come off
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 2,362
1 Commento
Thanks for the answer. Worked like a charm. Battery replaced in about 20 minutes
da Brian Thompson
