Salta al contenuto principale
1.5 Core Solo, 1.66 or 1.83 Core Duo, or 1.83 or 2 GHz Core 2 Duo processor. This covers the first Intel-based Mac Mini models from Early 2006 to Mid 2007.
142 Domande Visualizza tutte
Has anyone installed a SSD in a A1176 Mac Mini1,1?
Hi,
I haven't been able to find a successful installation description of a SSD in a A1176 Mac Mini1,1. Can anybody confirm it is possible? Can you recommend any SSD model?
Thanks,
Igor.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
4 Risposte
Soluzione Prescelta
An SSD drive is physically exactly the same as a regular SATA drive, with the same SATA connector. So as far as installation, there is nothing specific to SSDs, and you can therefore use the guide for installing a regular SATA into an A1176:
Installazione Disco Fisso nel Mac mini modello A1176
Punteggio 6
It's not a god idea to put the ssd where the optical drive is. That bus is very slow and will cripple your SSD speed. I believe the optical drive is on a PATA bus.
Punteggio 1
I just installed a ssd in my Mac mini with a 1.86GHz CPU.
It was very easy, the hardest part was taking off the top.
Once the ssd installed I just booted off my Snow Leopard DVD and done.
What problems are you having?
If you put your orignial HD into a USB enclosure you can hook it up and boot off of it first.
You will see the ssd as a attached drive in Disk utility program.
Format the ssd and install new OS.
Punteggio 0
Hi, is it possible to remove the optical drive and replace it with an SSD ?
Punteggio 0
Aggiungi la tua risposta
Igor Santos sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 4,084
