Hi,
Try the following.
Disconnect the charger from the laptop.
Remove the battery from the laptop.
Press and hold the Power button for 30 seconds. This will dissipate any residual charge in the laptop.
Reconnect the charger to the laptop and switch it on. Leave the battery out at this stage.
Try to turn on the laptop.
If it turns on allow it to boot all the way to the Windows desktop, let the HDD activity settle down then shut down the laptop in the normal manner.
When it has shutdown completely, switch off the charger and disconnect it from the laptop.
Reinsert the battery.
Reconnect and switch on the charger to the laptop.
Try to start the laptop.
If it starts, allow it to boot all the way to the Windows desktop.
Check the status of the battery charge.
If it is charging allow it to fully charge before switching off the charger and disconnecting it from the laptop.
Votato
Annulla
Punteggio
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
