Salta al contenuto principale
Lanciato da Samsung a marzo 2016. Modello SM-G930.
425 Domande Visualizza tutte
Wifi antenna in s7
Hello every one,
About a week ago I accidentally dropped my galaxy s7, although there were no visible damage to front and back but just after that I realized that my wifi range has become very weak.
I'm able to connect to my router if I stay close to it, but as soon as I starts moving away signal drops dramatically. This was not the case before my phone was dropped.
Someone told me that may be wifi antenna connection is loose.
So today I decided to open my s7, I successfully open the back cover but now I have no idea where the wifi antenna is. I search over the Internet some page says the antenna is at the top some says they are at the bottom.
So can anyone please tell me the exact location of where the wifi antenna is in galaxy s7.
It would be great if you can share images of that portion.
Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
There are two antennas that plug into the charging port, double they if they are plugged in both to logic board and both to charging port assembly.
After that if you are very careful with the antenna connection prongs you could lift the up very slightly, but don't do it yet unless you are still having wifi issues after reassembling the phone back together without the back cover glass installed.
Punteggio 0
2 Commenti:
Thanks for your reply
Can you please share any Image of that portion. It would be very helpfull.
Thanks
da
Here I have marked possible antenna locations:
http://prntscr.com/ioedki
da
Aggiungi la tua risposta
Muhammad Taqi sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 9
Tutti i Tempi: 2,721
