Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2692 Domande Visualizza tutte
How can I test a replacement battery to be 100% sure it's good?
I'm about to replace a battery for a client who lives out of town. In the past, I've replaced batteries that started malfunctioning within a couple days, but since this client can't easily come back for a replacement, I want to make 100% sure the battery's good before sending them on their way.
My plan is currently to plug in a battery, turn on the device, use the Battery Life app and do a stress test with video streaming. If it passes the tests, is this enough to be sure the battery is good? Are there any other tests that can make sure this battery won't start acting up in a couple days?
Thanks.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Your testing sounds solid. However, batteries are a curious beast due to their chemical nature. The best way to insure you have good batteries is to stick with quality suppliers. If you have had issues in the past with a certain supplier, you may want to reconsider things and find one who has a very high quality rate.
Punteggio 4
1 Commento:
Thanks for the reassurance. I'd still rather do the 2-minute test & deal with returns than spend an extra $10 per battery to avoid it. If you do the math, 2 mins x 30 x $10 = $600/hour. When I'm doing the annoying tests, I'll just remind myself that I'm getting paid $600/hour to do it.
da
Aggiungi la tua risposta
fdsajky675 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 85
