Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
2376 Domande Visualizza tutte
iPhone 4 clock losing time
I was asked today about an iPhone 4 (A1332) which seems to have a problem with the real time clock. Now and then it loses maybe half an hour and then recovers the correct time a day or two later. Text messages don't seem to come through when it's in that state.
I suspect it could be a problem with the RTC chip (probably not a separate chip but a function integrated into the processor or one of the peripherals) in which case it's probably not fixable.
Probably the only chance of a fix would be if it's a software problem, so I suggested backing up her data and doing a factory reset. But if the flash memory is getting tired a complete reflash of the kernel would be more likely to do the trick. Not sure how to do that. Ideas? Or other suggestions?
Regards - Philip
Questa è una buona domanda?
Punteggio 0
1 Commento
@pleriche this "Text messages don't seem to come through when it's in that state" sounds more like a connection issue. Check the antenna cables etc. If not check with a new Sim Card and see if that will help.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Real time clock is a waste of time to diagnose on a old phone. Better yet to get another 2nd hand iPhone 4 rather than try to fix the problem as it would be a lot cheaper and less time spent.
You could try restoring the phone via iTunes but you would need to do a backup first. I doubt it'll help though.
Punteggio 2
Aggiungi la tua risposta
Philip Le Riche sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 171
