Salta al contenuto principale
La versione 2016 del telefono economico Samsung Galaxy A3 (numero modello: A310F).
What can I do to fix a pink/purple screen with a white vertical line?
About a month ago, I dropped my phone killed my screen and I had it fixed.
Last night while I was charging my phone, it fell!
When I picked it up the first thing I noticed is that it had a vertical white line that ran from top to bottom and the area where the line was located could no longer work.
Then I noticed some pink/purplish lines running in all directions on the screen!
Now the whole screen is a pinkish purplish colour and the part of the screen where the white line was originally located has started to turn black, it is slowly progressing and I am guessing that by the end of the day my screen will be completely black.
Also, my screen isn't broken!
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Only solution is to replace the screen again.
Punteggio 4
  • sounds like you were playing a video.if you switch tabs during a tab many times it will come.remember,it might be 4 times
  • it could be screen problem
  • joining a meeting+playing a video ,it will come like that
Punteggio 0
1 Commento:
you`r screen will also off,please off it and on it again
da
Aggiungi la tua risposta
thea sku sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 8
Tutti i Tempi: 9,825
