Salta al contenuto principale
The Dell Inspiron 14-7437 is pre-installed with Windows 8, has 4th generation Intel Core processors and a 14-inch display.
8 Domande Visualizza tutte
My laptop is not charging, help!
Hi,
My laptop stopped charging recently. It works when plugged in but says "1%, not charging. Power mode (plugged in)." My first response was buying a new charger but the same thing happened. So I thought it must be the power jack. I ordered one on ebay and replaced it today. But the same thing happened - 1%, not charging...help! What else could it be?
Thanks Magda
Questa è una buona domanda?
Punteggio 1
3 Commenti:
Hi @magbrown? had you checked about the battery?
da
what are you doing while you have this issue? you doing anything resource intensive?
da
No, not at all. I’m just simply using my laptop whilst pugged in. When I unplug it the laptop imediatelly turns itself off :( Thanks
da
Aggiungi un commento
1 Risposta
Try replacing the battery, and/or the pins and cables connecting the battery to the power jack and motherboard.
Punteggio 0
1 Commento:
The laptop is only two years old. Do you think it could be the battery? Thanks :)
da
Aggiungi la tua risposta
Magdalena Browning sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 330
