Salta al contenuto principale
Guides for the LTE version of the iPad Mini 4—model A1550. Announced on September 9, 2015, the iPad Mini 4 is the successor to the iPad Mini 3.
iPad automatic shutdown by no reason
When I use my iPad like normally but sometime it alway shutdown automatic and cannot turn on .
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
This has been an issue recently, it is likely due to an old and degraded battery. This can occur when the device pulls too much voltage from a battery that cannot sustain it, so it shuts down to protect itself. Here is a part for replacement and here is a guide.
Immagine Replace a model A1546 battery compatible with iPad mini 4th generation.
3.82 Volts (V). 19.32 Watt Hours (Wh).
Prodotto
iPad mini 4 Battery
$32.99
Punteggio 1
11 Commenti:
Thank you for your advice.
da
But sir it the new iPad and then just open from the box.
da
@reedcrosby04
da
If it's a brand new device, then bring it back for a replacement.
da
Mostra altri 6 commenti
Aggiungi la tua risposta
Eden sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,396
