Salta al contenuto principale
Repair guides and support for LCD e-writer tablets manufactured by Boogie Board.
8 Domande Visualizza tutte
Parts of my Boogie Board are grey!
I have a Boogie Board (model 01582801516) and in one of the corners there's a large grey spot that won't go away.
Why is it like that? How can I fix it if it CAN be fixed?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
3 Risposte
Risposta Più Utile
Actually, Found this: Boogie Board won't erase
Punteggio 2
sounds like screen burn in. and probably needs a new LCD. how long have you owned it?
Punteggio 1
4 Commenti:
@captainsnowball boogie board tablets are cheap e-ink displays with a limited battery for clearing what you've drawn on it. After the battery runs out you can't clear it anymore. It's cheap and designed to be disposable. Sometimes points on the screen get dots that cannot be erased. Perhaps because someone pressures the screen to hard.
You should always google the device before answering a question.
da
I took a look at it. I have a kindle and I beleive its the same mechanism. but as he said, he cannot get it to go away. presumably he tried turning it on.
da
No Aiden, you don't turn it on. It's a very basic device. You write something on it, it stays there until you hit the clear button at the top which refreshes the screen once. It's a totally analog device.
da
I've owned it for a few years. I think I got it when I turned 10?
da
why does my boogie board have grey dots, WHY?!
Punteggio 0
1 Commento:
Mine has blue fading happening around the edges...
da
Aggiungi la tua risposta
Morgan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 23
Tutti i Tempi: 3,262
