Salta al contenuto principale
Annunciato nel marzo 2015 e lanciato il 10 aprile 2015, il Galaxy S6 era a quel tempo il top della gamma Galaxy. La versione con schermo curvo è nota come Galaxy S6 Edge.
487 Domande Visualizza tutte
Gluing the capacitive buttons to the back of the Screen assembly
Hi!
I just finished disassembling the S6 of a friend for a screen-replacement and noticed that I damaged the cable going from the daughter-board to the menu button. Since the buttons are hard wired to the daughter-board I ordered a replacement online. The replacement is in used condition (i.e. comes from another phone) and doesn't include any adhesive to glue the buttons back to the screen assembly. I have no idea what kind of adhesive tape/liquid to use.
Does it have to be electrically conductive?
What thickness should I go with if I choose a tape?
Thanks for any help
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
When you replace the charge port (which has the menu buttons on it) if you sit the cables down in their little cut-out positions and press the screen down that will be enough. The screen will put pressure on the buttons and it will be fine.
Punteggio 0
Risposta Più Utile
buy a new charge port and it will have adhesive, why did you buy a used 1 when they are cheap new
Punteggio 1
4 Commenti:
I bought the part in used condition because I wanted to makes sure it is an original part. The iFixit online store in Europe does not sell the part so I looked elsewhere. All the new ones seem to be knock-offs and I read mixed reviews on quite a few "original quality" parts on ebay and amazon. Any tips on the glue?
da
something like this should be fine https://www.ebay.co.uk/itm/3M-1mm-x-50M-...
da
Great, gonna try this one out. As far as I see there is no electric conductivity or anything special about it. Are you confident that the buttons are going to work as expected?
da
should be fine as i think the touch is detected from the light being covered with a thumb or finger
da
Aggiungi la tua risposta
Filippos Bamopoulos sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 145
