Rear Brake light is out and its not the bulb.
Rear Brake light out and both brake a front blinkers work on and off with the light flickering fast when it does work. Help
Questa è una buona domanda?
OhhhK. When your indicators flash fast, usually that means that one has blown or has a fault. Or it could be your indicator relay.
If the rear brake light is out and it isn't the bulb, then it can only either be a fuse, relay or wiring. I'd check your fuses first.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 106
