Salta al contenuto principale
The LG Xenon GR500 is a QWERTY keyboard cellular phone with a camera.
Why are my texts displaying in the wrong order?
I recently started using a new LG GR500, and i noticed an issue of the texts not displaying in the correct order. When i text someone, all my texts are on top, and theirs are on the bottom. in other words, they are not displaying in chronological order. i have looked this up and other people with other phones have had this problem, but just switching the automatic date and time off then on worked for them but that did not work for me. i have also tried a factory reset and master clear and master reset, none of which worked. it quite obviously sounds like a software glitch. does anyone know of a fix for this?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Risposta Più Utile
Someone posted a similar statement with the phone you have. Apparently it is common, and one of the fixes is the calendar. Check the date and time and make sure it's current. The last option, from the carrier, was to master reset the phone under reset settings.
Hope this helps
Punteggio 2
6 Commenti:
all good except- you forgot to mention where it came from with a link. worthy of an upvote from me either way.
da
The link was not a guaranteed solution, so I did not bother because it's more of a theory.
da
still, the answers may help. but I see why you did not. I'm not going to force you to include the link because if you're like me you probably lost/forgot the link.
da
no. That's why there is a history in the browser.
da
Oh yeah... Forgot.
da
Mostra 1 altro commento
Are you on good wifi? I remember this happened to my iPhone and stopped doing that after going back onto my home network. (texts did not return into the correct order, just stopped putting making new ones in the wrong order.)
Punteggio 1
3 Commenti:
This phone is from 2009, so it actually doesn't have Wifi capabilities!
da
cellular then.
da
well, in that case, my cellular connection is fine. it isnt like the happens on and off, its just constantly like this no matter my connection
da
Aggiungi la tua risposta
Randi sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 29
Tutti i Tempi: 287
