Salta al contenuto principale
Repair guides and support for the EOS 70D, a DSLR camera released by Canon in 2013. This camera can be identified by the model number DS126411.
66 Domande Visualizza tutte
Green lines across my images
I purchased a Canon 70D over eBay and on all the manual settings, the images have two solid green lines across them. This could indicate a possible sensor problem, however, if I shoot on Automatic the lines are not there - could this be possible?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Had a similar problem with a 5D MKIII, replaced the Sensor Ass'y, Main PCB & Mirror Drive PCB with test parts and didn't fix it, figured Main PCB was corrupted so downloaded and installed Magic Lantern (only on the memory card) ran the test's it comes with and fixed !!!
Punteggio 0
Change the aspect ratio of raw images to 3:2 or the default that it came with and you can crop it latter
Punteggio 0
Aggiungi la tua risposta
Nell Delport sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,067
