Salta al contenuto principale
Modello A1312 / metà 2011 / Processore Core i5 da 2,7 e 3,1 GHz o Core i7 da 3,4 GHz, ID iMac12,2
708 Domande Visualizza tutte
Is it possible to use the same sata cable for SSD drive bay?
Is it possible to use the same sata cable, the one already used for connecting the optical drive, for connecting an SSD drive bay? I mean without detaching the logic board for plugging the sata cable in a different sata slot.
My intention is to install an SSD just removing the screen and the optical drive, using an ssd drive bay and an external usb case for the OD.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
You do realize you have three SATA ports in your system: HD, Optical drive & Spare
So you don't need to take out your optical drive to add the SSD (it will use the spare port). If you wanted to have three drives (HDD, SSD1 & HDD2 or SSD2 for the optical drive) then I could see that might make sense!
Here's the IFIXIT guide to add in the Spare port SSD: Installazione del Kit Doppio Disco nell'iMac Intel EMC 2429 da 27".
If you want to push your system to the max then you could do this: Installazione dell'SSD Dual Drive nell'iMac Intel EMC 2309 ed EMC 2374 da 27"
The part cost for either is the same ($20 US), yes the first is a bit more work but you don't loose your optical drive and you still need to add in the cost of the case to hold your drive. Lastly, the optical drives SATA port is only SATA II (3.0 Gb/s). So in my option I would do the first way as it will give you the higher speed I/O SATA III (6.0 Gb/s). And I would set it up as the boot drive.
Immagine iMac Intel 27" EMC 2429 Kit Doppio Disco
Guida
Difficoltà:
Difficile
1 - 3 hours
Immagine iMac Intel 27" EMC 2309 and 2374
Guida
Difficoltà:
Moderato
1 - 2 hours
Punteggio 2
2 Commenti:
Will this incur fan issues?
da
Adding the SSD via the spare connection? I don't see why it would.
I could see an issue if you forgot to transfer the thermal sensor on the optical drive if you went that way ;-}
da
Aggiungi la tua risposta
Tullio sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,998
