Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Is my battery at fault?
I've inherited an iPhone 6 which a friend has recently upgraded from due to "battery problems", as I was told, and I'm trying to get it back into a usable state. When not connected to power, the device remains powered off completely. When plugged into power, the device seems stuck in a boot loop. It powers on, light grey background with Apple logo for about 15 seconds, then screen switches off for a couple of seconds, then back to the first screen.
I can put it into standard Recovery mode, but attempting to Restore & Update results in an error 4013. Putting it into DFU mode and trying the same gives an error 4005 (eventually, takes a lot longer). Tried on both Mac and Windows machines, a couple of different cables, just in case, but identical results. Device has no sign of any physical damage.
Now my question is: Does this describe a situation where the battery has (effectively) died, and what are the odds that replacing the battery will give me a fully functional device?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
4013 and 4005 are NAND related issues, the memory chip on the logic board needs to be at least removed reballed then reprogrammed. All done via board-level repair / microsoldering.
It's probably going to be hard to find someone in your area that does that job as it's very tedious to do.
Punteggio 2
2 Commenti:
That would be annoying. Curious that Apple's KB article for those errors seems to indicate that retrying with different cable/computer/etc may resolve them (but then that's Apple's answer to most things). Was really hoping a fresh battery would solve all my problems. Any idea the ballpark price I'd be paying for your suggested fix? Might be better stripping for parts.
da
$120-$180 around there. Requires more work than replacing charging chip.
da
Aggiungi la tua risposta
Endareth sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 71
