magsafe charger is overheating and sometimes laptop does not charge.
The charging symbol sometimes has a white background with the electricity signal but it often does not charge the macbook.
Questa è una buona domanda?
At this point you're going to need to pop the logic board out and do a detailed inspection on both sides. Follow this IFIXIT guide: MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement. I'm suspecting you have some corrosion or a failing chip on the logic board.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 513
Did you have a liquid spill or sit the system down on a wet surface at some point?
da Dan
