Salta al contenuto principale
Modello A1419 / EMC 2806 / Fine 2014 o metà 2015. Core i5 da 3,3 o 3,5 GHz o Core i7 da 4,0 GHz (ID iMac15,1); EMC 2834 fine 2015 / Core i5 da 3,3 o 3,5 GHz o Core i7 da 4,0 GHz (iMac17,1) Tutti con display Retina 5K.
573 Domande Visualizza tutte
possible to replace thunderbolt ports?
Is it possible to replace worn out Thunderbolt ports on a 2014 iMac 5k 27"??
What parts would be needed? I love my imac, but I think using the thunderbolt ports for my monitors have just worn out to where the monitors will blink on and off when the connector-adapter moves. Those are fine, i tested them... but I think something inside the port is just worn out or something?
ANY SUGGESTIONS??
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Not good ;-{
The iMac's all use a frame which holds the ports on the backside of the logic board as you can see here:
So if your port is worn you'll need to replace the logic board - Ouch!
If you can, try using a hub to off load the constant wear. Or, if you can, try replacing the monitors cable (The Thunderbolt display cable can be replaced)
Punteggio 1
Aggiungi la tua risposta
Jeremy Williamson sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 778
