Salta al contenuto principale
The OnePlus 5 (OP5) is a 5th generation smartphone released June 20, 2017. It is the successor to the OnePlus 3T and predecessor to the OnePlus 5T.
52 Domande Visualizza tutte
Where I can get this charging port
Now my phone is dead for a whole month because of a small piece
i am looking for that piece because it is damage can you tell me where i can buy it or what is its the correct name for it?
http://www.m5zn.com/newuploads/2018/02/1...
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
My guess is it would be the charging port daughter board.
https://www.eddogo.com/for-one-plus-onep...
Is it the charging port assembly or the connector on the logic board broken?
If it's the connector on the logic board broken you will need to take it to someone that does micro-soldering to replace the part, they most likely will have to order a replacement FPC connector for that too.
Punteggio 2
1 Commento:
it is the connector on the logic board
do you know where i can order the replacement FPC connector??
da
Aggiungi la tua risposta
thamer sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 5
Tutti i Tempi: 394
