Is it possible to repair the twist-switch on the Maglite Solitaire?
Even when it is the 'twist-on' position, the flashlight keeps flickering and switching off by itself. Is there a way to repair this?
Questa è una buona domanda?
Yes. You can get all replacement parts on ebay e.t.c.
Probably don't need anything in this instance.
These instructions will work for similar brands or makes of screw style torches with conventional or LED bulbs.
From my experience it can be, in order of most common:
# Fingers crossed if you follow all these in order you should have a working torch for many years longer. yeh! Give me a thumbs up. Many thanks in advance ;)
Thank you so much, Jason G!
All I had to do was to extend the spring a bit and it works perfectly now :)
I certainly need a refresher course in common-sense :P
Isopropyl is an alcohol. Isopropyl IS NOT NAIL POLISH CLEANER!!! There is no such thing as "nail polish cleaner", but there IS such a thing as "nail polish remover". Don't use nail polish remover, as it contains acetone and will corrupt metal.
Updated. Thanks for your assistance.
I first thought there was an issue with the screw mechanism because the light would give very short bursts of light, but after putting in a fresh battery it works again like a dream. Thanks for the tips.
Glad you ifixed your torch :)
Like I mentioned above. You have to be careful about the length of the batteries. rechargeables seem to be a couple of mm shorter in some cases.
Also unscrew the top & make sure the plate where the top of the battery meets is clean. Just use some isopropanol or if you don't have that nail polish remover is ok. It is all about getting good electrical contact. All the Best Jason G
Hi! I have the same problem, when i screw it tightly, my torch wont turned on then when i loosen it slightly, it is functioning. What could the problem?
Thank you.
Have you been methodically through the steps 1-5 above?
All the Best
Jason G
Ultime 24 Ore: 2
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 69
Tutti i Tempi: 6,051
