Salta al contenuto principale
Repair guides and support for the ZenFone 2 by ASUS, identifiable by the model number ZE500KL. Introduced in September 2015.
14 Domande Visualizza tutte
Stops charging after a few minutes
Hi. My Asus Zenfone 2 Laser is not charging properly. When I plug it and the battery reaches 30%, it stops charging. I have tried charging it on a safe mode and I've also tried resetting it. Nothing has changed. I've tried restarting the phone whilst it's plugged. It does charge,l. However, after a few minutes, it stops charging again. What could be the problem? Do you have any solution for this? Thank you
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Battery related. It's either the phone is not registering the battery properly OR the battery is just failing and needs to be replaced.
If you know a shop that has a battery tester kit they can diagnose it and determine if that's the issue or not.
Otherwise, replacing the battery would be another option
Punteggio 2
1 Commento:
Yep, I know this is a year later, but yes, I had this same problem. I had to replace the battery to fix it. The "new" battery lasted about a year before doing the same thing. All you can get now are 3rd-party or salvaged batteries for it.
da
(I 2x posted so the OP could see the answer as well.) Yep, I know this is a year later, but yes, I had this same problem. I had to replace the battery to fix it. The "new" battery lasted about a year before doing the same thing. All you can get now are 3rd-party or salvaged batteries for it.
Punteggio 0
Aggiungi la tua risposta
Christopher sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,962
