Salta al contenuto principale
The Xterra was introduced in North America in the 2000 model year (1999 calendar year) and marketed using the tagline Everything you need, nothing you don't.
I think I busted my timing belt
I have a supercharged Nissan xterra, it was really low on gas so i drove to get it gas, but it wouldn't go over 20mph unless i put it in supercharge got gas it was fine driving out of the gas station but then it would only go to 20 again i got it to 45 almost turning onto the freeway and it turned off in the middle of driving it i made a u-turn and the power streeing went out thats how i know it shut down, it wont start up now, it will act as if it is going to turn on but never really starts up? now when i check the reader it says camshaft or crank shaft sensor (not sure witch one), but it didn't have the code there before this happened.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Check the distributer. I was traveling down the highway, and it was running rough, so I slowed down and ended up going 20, before having to just finally pull over. The bearing had gone out in the distributer. I bought a new one for about 200, installed it, and it runs great now, 30,000 miles later. I'm at 230,000 now.
2001 Nissan Xterra XE
Punteggio 0
Ditto on the distributor. Mine went out as well and the car was really struggling. Took the old one out, and just like @ifoster, a bearing seems to have gone out. Replaced with the distributor assembly from my parts car and now it’s driving great again!
Edit: I have a 2000 XTerra.
Punteggio 0
Aggiungi la tua risposta
morganh769 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 367
