I get a message "prime" what does that mean?
After brewing a couple of cups, I get a message that says "Prime" the machine will not work unless I unplug and re-plug. What do I need to do to keep that from coming up?
Questa è una buona domanda?
James young it is possible that you get the Prime message because the water does not drain from the reservoir. Your reservoir has a filter in the bottom which may be dirty, or your needles are clogged. there could be debris clogging the needle. Use this guide Come aprire e pulire una macchina da caffè Keurig to work on that. Let us know what you find after.
Ultime 24 Ore: 12
Ultimi 7 Giorni: 61
Ultimi 30 Giorni: 276
Tutti i Tempi: 3,872
