Salta al contenuto principale
The OnePlus 5 (OP5) is a 5th generation smartphone released June 20, 2017. It is the successor to the OnePlus 3T and predecessor to the OnePlus 5T.
51 Domande Visualizza tutte
Does recording in 4K have any problems with image stabilization?
I was wondering if there is any problems recording videos in 4K while trying to use the "image stabilization" function. Thank you.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
If you shoot videos in 4K, the electronic image stablization will not work. If you are staying still and recording the footage will turn out great. But if you are moving around it will be very shakey. You could always lower the resolution to 1080p. If you are recording at 1080p the image stablization will work.
Punteggio 0
Aggiungi la tua risposta
Raphael Maciel sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 46
