Salta al contenuto principale
Device and repair guides for the RCA 10 Viking Pro, an Android tablet with detachable keyboard that can be identified by model number RCT6303W87 DK.
bypassing settingslocked password after factory reset
I factory reset my viking 2 tablet model number rct6603w47 but now I get this settingslocked message when I try to pick language how do I bypass or unlock the settings it is a display model from target is it possible to reprogram or bypass settings locked password
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
6 Risposte
Soluzione Prescelta
try the default password which should be 0530. you can usually find it online.
Punteggio 0
7 Commenti:
The default password doesn't work
da
Not really sure what else to say because i have not been able to bypass this on the newer models. i would think a factory reset would reset this password to default but that may not be the case.
da
i used 20160502 for pro12
da
I found number in recovery mode
under view recovery logs
top one in those lines says recovery logs
then look for line that says rca password.
that is how i found it.
good luck
da
exelente me funciono del metodo comentado
good luck
da
Mostra altri 2 commenti
Risposta Più Utile
The password is different for each tablet. If you go to recovery logs in the reset, choose the top one and slowly scroll down and it will
ro.build.version.sercuity_patch=2016-06-01.
The settingslocked password is is those 8 numbers is what I found mine to be. So that everyone has the answers finally.
Punteggio 2
2 Commenti:
mine said rca lock key 20160502
da
Yes that is the same thing as well it is really the date in which it was made.
da
Punteggio 1
1 Commento:
mine, too! So it was manufactured the same year?
da
I tried it but it didn't work, keeps asking me for the previously synced account!
Punteggio 0
1 Commento:
This is a completely different thing. SettingsLocked is basically a feature to lock the settings for store demo devices. Yours sounds like you factory reset it using the volume button method and thus that is how this one happens.
da
Sorry for bumping an old thread I have two of these Viking 2 10 inch that have same issue, but i tried the security patch date and and the date it was made but still locked..any help would be appreciated
Punteggio 0
Hi,
You have 3 other options. In recovery logs look for
ro.boot.hardware=mt****
use the 2 letters and 4 numbers you see.
Next,
ro.boot.serialnumber=***********
use the first 8 digits or the whole serial number.
3rd,
ro.build.id=MRA58K
use the letters an numbers exactly as they appear.
Hope this helps you.
Punteggio 0
3 Commenti:
i had tried every thing but setting locked is still annoying
da
i have bought RCA viking 2 from someone but has setting locked, and cannot connect to PC i have tried Factory Reset ,recovery mode, insert default pasw 05230 but i am failed :) if anyone can help would be appreciate
da
Just received a 2019 RCA Endeavor tablet locked in retail mode from what appears to be a previous Target store display....anyone know what the password might be? TYIA
da
Aggiungi la tua risposta
dak joe sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 48
Tutti i Tempi: 5,899
