Amazon Fire Stick not powering up
What to do with an Amazon Fire Stick that will not power up?
Questa è una buona domanda?
I have a Amazon Kindle Fire, but what do you mean by 'Stick'?
The amazon fire stick is something that plugs into your TV allowing you to watch amazon prime video on it.
This is the fire TV stick: https://www.amazon.com/dp/B00ZV9RDKK?tag...
Make sure that you are using the power supply provided with your Fire TV Stick device. You can connect the included power adapter into the power port on the back of your Fire TV, then plug the other end into a power outlet.
To resolve the error, try the following required step as mentioned by the Amazon Fire Stick Support.
* Plug out the cord and restart the device.
Before I factory started my firestick it was not finding my Network or any around me. So I factory started it, and now I can't get past the setup because it's still can't find any Networks. Can somebody help me with this????
Ultime 24 Ore: 4
Ultimi 7 Giorni: 29
Ultimi 30 Giorni: 192
Tutti i Tempi: 13,679
