Salta al contenuto principale
The Samsung Galaxy J1, released January 2015, model number SM-J100VPP.
107 Domande Visualizza tutte
Will not turn on, Just vibrates when on charge and has new battery
Hey guys i have a samsung j1 i left it at home one night and when i came home it was flat i tried to turn it on it didnt turn on so i put it on charge and it just vibrates every 5-10 seconds continuously and i have replaced the battery and it still just vibrates on charge and whrn you try turn it on it vibrates to let you know it has switched on but then nothing happens and i need pictures and data off the phone
Questa è una buona domanda?
Punteggio 6
6 Commenti:
@telfz0r Is it still being recognized by your computer when plugged in? this sounds like a display issue since that is what could make it vibrate.
da
HEY i have the exact same problem no visuals on the screen just the rythmic buzz every 5 seconds letting you know that your lifes a failure and nothing will ever be right again. If you solve this problem please let me know :)
da
Anybody find a fix ?
da
fml :( buzz buzz
da
mines is doing the same thing
da
Mostra 1 altro commento
Aggiungi un commento
4 Risposte
Option one: Try a new charger.
Option 2: Go to a service center and replace the charging panel
Punteggio 0
3 Commenti:
Sometimes when a charger is in the same position for a while, this happens. It will only charge in a specific position, which explains the continuous vibration. It is simply charging in one position, then not charging when you move it even slightly. You need a new charger.
da
No its not the charger I have tried 5-10 different combinations of power connections and USB cords
da
Mmm...I'll keep that in mind.
da
try replacing the screen
Punteggio 0
Hi,
This might be because of 2 reasons
  1. You may be decided to turn on a phone whoch was switched off for like months or weeks.
  2. If you have new battery issues or battery replacements
So you may try charging using a high power adapter and the original working cable. Along with this try cleaning your phone charging port using toothbrush (with petrol drops if required)
Punteggio 0
What if the phone had got in contact with water and then it starts vibrating without turning on or showing that it's charging after 3-4 days of drying off?
Punteggio 0
1 Commento:
It's a Samsung J7 pro
da
Aggiungi la tua risposta
Jake Walters sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 88
Ultimi 30 Giorni: 305
Tutti i Tempi: 16,527
