Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Help Please!Problem with iPhone 6.:-(
Actually, the iPhone was perfectly normal...Once i kept the iPhone beside my head and unfortunately that day, water from the air conditioner(above my head)fell inside and made my iPhone completely wet as the droplets of water fell directly on the earpiece...I was shocked to see the iPhone in the morning...I tried to jerk my iPhone and there was huge amount of water coming out from it as if it was a spray can..I removed the sim and opened it up and removed the battery and kept it inside rice for 2 days..
the phone was completely dried and then i tried to insert the battery again and the phone to the surprise turned on and yeah the phone was perfectly normal for more than a month however the plastic indicator in it became red and the screen had certain white spots but the earpiece speaker everything was sounding right...i was running ios 10.3.2...everything was perfect...
After some days when ios 11 was out,i tried to update the iPhone and thats when it all went away.. the phone perfectly turns on and after 1-2 mins..it will suddenly flash a black screen and restart...this has been very very annoying..i checked the analytics and its full of kernel panics bug type 210,211 blah blah.. the thing which i couldn't understand is that, how was it running perfectly in ios 10.3.2 but not in ios 11.2(presently)...
Even i replaced the battery and the old screen which had some white spots in it... i also cant downgrade to ios 10.3.2 anymore..so stuck..:-(..i just need to get rid of the random reboot problem and everything is fine..and i am not in the mood of getting a new one or to get it replaced as it has gone quite old...Any helps would be highly appreciated...Feeling helpless:-((
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Have you tried updating the phone through iTunes? You will need to force the phone into recovery mode, use the instructions linked here but do not restore if you want to keep data on the phone:
https://support.apple.com/en-au/ht204306
Punteggio 1
9 Commenti:
I already did that. That is how i updated my iphone to 11.2.Actually there is nothing important in my iPhone.
da
Then you have nothing to lose in trying the restore option.
If you have a iTunes restore error code, post it here.
da
I already tried it at least 5-6 times..I still have those ipsw files.. It doesnt seems to help.. I am running iOS 11.2.5 now which also I restored using itunes..
And one more thing I want to tell is that the reset counter starts only after I unlock it...I mean once I unlock the iPhone with my touch ID, then correctly after 1-2 mins it will reboot randomly... Before unlocking it, it wont resart...I can give you the analytics data if you need it..
da
Okay, then there is probably still some liquid damage corrosion on the logic board under the metal shields as thats where water can set in and is hard to clean out without lifting up the shields.
Removing those shields require a rework station to do properly and that is basically a job for micro-solderers to do.
da
OK, but ben one thing I don't understand is why didn't the phone pose such problems at the beginning itself..the annoying thing is that it was perfectly normal but suddenly started showing up random reboots after 2-3 months... Is it like water damage problems are posed after 2-3 months??...lol...what I think is there may be any software issues as it was normal at 10.3.2 and abnormal at iOS 11.2.5..what do you think ??
da
Mostra altri 4 commenti
some one tell turn off auto brightness. it will be done
Punteggio 0
Aggiungi la tua risposta
Harishvar Akaash sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 157
