Salta al contenuto principale
The Samsung Galaxy Note 5 (called the Note5) is a phablet-style phone with stylus, manufactured by Samsung, released in August 2015.
271 Domande Visualizza tutte
wont turn on or charge after dropped
My phone wont turn on anymore. I already did the hold home volume up and power button. Still doesnt turn on. Try to charge it but the phone still doesnt turn on and it keeps overheat when i left it charge it.. Then i try to investigate i removed the back cover of the phone then i saw my battery's connector to the motherboard is cut off. Kindly see the image link below. My question is it possible to fix this or do i need to buy a new battery? I think this is the one cause of the problem not 100% sure
https://imgur.com/a/8fWpk image 1
https://imgur.com/a/aAKxR image 2
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi!
It's almost impossible to re-solder the battery ribbon connector, unless you have very good micro-soldering skills and are willing to put up with the risk of causing a fire while working with the hot soldering iron near the battery. Try replacing the battery, as you said, that should be a good place to start from.
Punteggio 2
3 Commenti:
Okay thank you. Later ill buy a new battery and check if the issue still persist
da
and one more thing. after i remove the back cover. There is a white thing like stickers on both sides. and i just cut them off. is this important on the phone? should i buy a new cover too? sorry not really familiar with this. so that i im not going back and forth.
https://imgur.com/a/HKsyG
da
Hi!
If the white things you cut trough are sticky to the touch they may need to be replaced, other than that no. I can't remember if the Galaxy Note5 was waterproof or not, but after this repair it won't be any more. Just keep that in mind.
da
Aggiungi la tua risposta
Jomai Masangkay sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 15
Tutti i Tempi: 2,730
