Oxygen sensors location places
Locations of oxygen sensors on a 1996 chevy c1500 5.7
Questa è una buona domanda?
@symphony2627 best to see and to get to with the vehicle on a lift.
Oxygen sensors bank 1 is any sensor upstream the catalytic converter and bank 2 is downstream. you'll have one before and one after the catalytic converter. Even so the attached image shows a dual exhaust it also applies to single exhaust but will of course only have two sensors. This video might help you further.
Am curious why the site says this answer was unaccepted... seems like it shows exactly where they are...
Probably because it is incorrect.
Bank 1 and Bank two refer to the primary exhaust pipes coming off each exhaust manifold.
On this vehicle, and any GMT800, Bank 1 refers to the Left or Driver's Side; Bank 2 refers to the Right or Passenger Side.
Sensor 1 and Sensor 2 are also called the Upstream and Downstream sensors.
Sensor 1 is the Upstream sensor and is located before the Catalytic Converter.
Sensor 2 is the Downstream sensor and is located after the Converter.
@Charles Colfax looks like that is what the answer says.
Ultime 24 Ore: 2
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 83
Tutti i Tempi: 8,154
