Salta al contenuto principale
Il primo smartphone Huawei con il nuovo chip Kirin 970. Rilasciato a novembre 2017.
Can a broken back glass for huawei mate 10 be replased?
I craked the glass on the back of my mate 10 while hiking . Can it be just replaced ? the cameras are fine and it works perfect it is just craked.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Yup,
Go to your local repairstore, they should repair it.
Although most of them will replace the glass and the lcd. Since the cost of removing the glass and glueing/curing a new glass over the existing lcd is too expensive (calculating the risk of a bad job).
Kind regards,
Punteggio 2
5 Commenti:
oh glad to hear it can be replased but it sounds like it is going to be expensive =(
da
aurora, tom has obviously read your question wrong and thinks its the glass over the lcd instead of the rear glass
da
you can find the replacement part here https://www.vopmart.com/pa1015011.html. then watch this video https://www.youtube.com/watch?v=Ps2cokN6... to see how the glass was taken off, then stick down the new piece
da
Thank you Daniel !!!
da
True, my bad.
But it can be fixed as well as Daniel stated!
da
Aggiungi la tua risposta
Aurora sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 7
Ultimi 30 giorni: 34
Tutti i Tempi: 4,543
