Salta al contenuto principale
Un discendente dello smartphone LG V10, simile all'LG G5, rilasciato il 29 settembre 2016. L'LG V20 si distingue per i numeri modello F800, H910, H918, H990 DS Dual, H990N Dual, H990 T, LS 997, US 996 e VS995. È disponibile con finitura titanio, rosa o argento con 32 o 64 GB di memoria interna.
Replacing connector for top antenna?
I damaged the connector for the top antenna on my LG V20 during screen replacement but I am unable to find a supplier for the part. I am not even sure what to call it and was hoping someone might know as I cannot connect to my wireless carrier since the phone repair. The part, a sticker which I believe connects the top antenna to the bumper, is circled in red in the image I linked.
Part circled in red
Questa è una buona domanda?
Punteggio 4
1 Commento
Did you ever find one of these? I need the same thing.
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
I did the same thing with the 2 pins near the headphone jack. (these connect to the “cellular upload” antenna at the bottom. I was able to figure this out because I wasn’t getting any upload when the pins were gone) I don’t think you can buy the pins separately anywhere on Ebay. I happened to have some conductive adhesive copper tape available and tried making a make-shift pin down there. Overall, it seems to be working for me now, but it’s probably a temporary solution at best. I noticed my download/upload rate drops down more than usual in areas where the cell phone network is weak. However, while driving my download/upload speeds seem to be just fine.
Punteggio 1
1 Commento:
That's what happened to me - one of the pins broke. The cell signal started to be unstable, especially where weak. Download worked somehow, upload did not at all.
da
https://www.nightlifemumbai.com/
https://www.nightlifemumbai.com/about-us
https://www.nightlifemumbai.com/services
https://www.nightlifemumbai.com/portfoli...
https://www.nightlifemumbai.com/rates
Punteggio 0
Aggiungi la tua risposta
Bernard Eeles sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 7
Tutti i Tempi: 2,371
