Salta al contenuto principale
Repair guides and support for your Samsung TV.
2614 Domande Visualizza tutte
Thick shadowy black/green vertical line
Hi,
I've got a thick black/green line that goes top to bottom on the left side of my screen.. it's not solid, it's like a shadow. You can only see it on certain pictures, it's particularly visible on a blue sky. Or solid colour background.
Anyone know what it might be?
TV is a Samsung hu7200 65". It's about 2.5 years old..
Thanks
David
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Risposta Più Utile
@huskymanwhat you have here is a broken panel. Check the crack lines etc. There is no repair for it but it will have be replaced.
The major issue will be to find a replacement. If you can find it, it will most likely cost more than a new TV. You could check places like ebay or craigslist to see if you find the same make and model TV as yours that is broken other than the display. Then harvest the display from that.
Punteggio 1
It is probably just that some of the pixels on that side of the screen are not registering some colors so you will probably have to replace the LCD.
Punteggio 0
I have a ibell b LED TV and their is a horizontal green line at the top of the TV please tell any solution
Punteggio 0
3 Commenti:
@akshay123 you'll have to post a "clear" image of your complete screen.
da
Ok, but the green line appear in half hour when i start the tv
da
I have a ps4 when i was playing i saw a green horizontal line at the top of the tv can anyone sayis their any problem in ps4
or in the tv
da
Aggiungi la tua risposta
David Johnson sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 4,639
