Salta al contenuto principale
Modello A 1297 / Processore Intel Core 2 Duo da 2,66, 2,8, 2,93 o 3,06 GHz
Upgrade of Logic board
Hello All,
I have a 2006 17" Macbook Pro with the 2.1Mhz processor in it...
I would like to now if I can upgrade my logic board to a faster model.. 2.6 or 2.8Mhz?
I looked online but did not see anything for a 17" I did see something about a 15"...
Thanks for all the info.
Aaron
Questa è una buona domanda?
Punteggio -1
2 Commenti
Is this your machine?
Apple MacBook Pro "Core Duo" 2.16 17" Specs
Identifiers: MacBook Pro 17-Inch - MA092LL/A - MacBookPro1,2 - A1151 - N/A
da
Mayer, Yes I beliee that is the exact machine that I have at home... Can I upgrade my logic board.. Im a designer and need more power but cant afford the cost of a new laptop.. Thank you
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I found nothing about being able to upgrade your logic board. It appears your machine will only take 2 GB of RAM. The only thing left is a hard drive upgrade to a 7200 RPM drive like a Western Digital Scorpio Black 320 GB or an SSD drive, like these: http://eshop.macsales.com/shop/internal_...
You could also switch out the optical drive using a optical bay hard drive adapter and use an external optical drive.
Punteggio 1
Aggiungi la tua risposta
aarontaylor13 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 607
