Salta al contenuto principale
Touchpad Pointer prematurely executes when it "hoovers" over something
When using the touchpad, and moving the pointer around, if it moves across an executable item, even "hovering" over it for a split second, it executes that command before you "click" on the touchpad left button as you would expect to do.
This is horrible, and I can't imagine that this is the way it's intended to work. Is this something that can be fixed with a setting change, driver change, or otherwise?
Questa è una buona domanda?
Punteggio 0
1 Commento
What Operating system are you using?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Looks like I've found a "fix"; in "settings", touchpad, turn off the "finger tapping" option -- this seems to have worked ok.
Punteggio 0
Aggiungi la tua risposta
Byrne Whitehead sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 134
