What's the Capacity of Model 110 series 26432501?
Questa è una buona domanda?
Kenmore 110 Series Washing Machine series washer capacity is 3.2 cu. ft.
I have a washer that was in my condo when I bought it and need to replace it but want to know the capacity of the one I have. The model is 110.26422502. The serial number is CT0531376. Appreciate any help.
To calculate the capacity (volume) of the tub, you multiply the area by the height. For example if your washer has a tub radius of 10 inches and the height is 14 inches, you would use the mathematical equation below.
Area is pi x r-squared = 3.1416 x 10-squared = 3.1416 x 100 = 314.16.
Volume = 314.16 x 14 = 4398.24 cubic inches.
There are 1728 cubic inches per cubic foot, so you divide 4398.24 by 1728 = 2.5452777 cubic feet.
So the cubic feet of capacity of this washer would be 2.5.feet
Hi,
A quick way to do this is like finding the volume or cubic capacity of a cylinder, where the washer tub is the cylinder.
Calculating the Volume of a Cylinder
1. Measure the width of the tub and divide by 2 to get the radius.
2. Calculate the area of the tub:
To do this, just use the formula for finding the area of a circle, A = 3.14 x r x r (where r is the radius)
3. Measure the depth of the tub
4. Multiply the area by the depth.
Use the same measurement base e.g. feet for both the radius measurement and the depth measurement.
The answer will be in cubic feet.
Ultime 24 Ore: 8
Ultimi 7 Giorni: 45
Ultimi 30 Giorni: 236
Tutti i Tempi: 42,622
1 Commento
110.20022013 what is the capacity
da Tony McClellan
