Salta al contenuto principale
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
20 Domande Visualizza tutte
Will the laptop run w/ no CD ROM drive?
My CD ROM drive is shot. I don't want to replace it. Since I never use this CD ROM, I was wondering if I could remove it.
Will the laptop still boot and run normally w/ no CD ROM drive?
thanks and happy new year,
=brian
Update
Thank you for the replies. I will do so.
"If thy CD ROM drive offendeth thee, pluck it out."
=brian
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Hi! Yes, it should work fine without a CD-ROM. Unless there's a reason you want to remove it, you could always leave it in place and save yourself the trouble.
Also, in case it's of interest, there are kits that let you mount a second hard drive in the CD-ROM bay, in case having more storage space would be more useful to you than an optical drive. If you're interested in one of those, let me know, and I'll find you a link.
Punteggio 2
Yes u can. I used this exact machine for almost a month with no superdrive till i purchased a newer version of the original. Just follow the guides provided here. Some people even opt. to use the superdrive space for an extra drive. Depends on your specific needs.
Punteggio 1
Yes, it will run, there's nothing about the superdrive that is required by the system to boot.
Punteggio 0
Aggiungi la tua risposta
surfcow sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 919
