Salta al contenuto principale
The Lenovo ThinkPad X1 Carbon 2nd Gen is the second generation of Lenovo's X1 series ultrabook.
6 Domande Visualizza tutte
No backlight with blown fuse under lvds connector
Good day
i have thinkpad x1 gen2 with black screen, i can see faint image with torch and external display works fine, i disassemble it and saw a blown fuse under lvds connector on main-board, i replaced it with same fuse and it blown right away after single test, there is an 8pin IC next to the fuse which i believe to be for black-light or something which is not good i think, i want to replace it but i can not read its number so i can order it, will someone help me identify this IC,
https://ibb.co/bGjPe6
https://ibb.co/mz0msR
Thanks
Questa è una buona domanda?
Punteggio 1
1 Commento
I found Fuse 1 blown replaced it .
the Fuse is on the opposite side of the motherboard where the screen connector to motherboard is , it is covered in sticky protective plastic.
unfortunately to me the laptop stopped powering on something else has happened to it that I could not fined yet.
Power starts green light flashes then the fan starts then power off follows
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
On my X1 carbon gen3 it says F:2B on that IC.
Punteggio 1
1 Commento:
Thanks alot Jarlvik, Yes it is F:2B but just cannot find it anywhere on internet. Greets
da
Aggiungi la tua risposta
Khizar Hayat sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 25
Tutti i Tempi: 2,667
