Where is the thermostat on a 1997 Nissan truck 2.4L engine
My mechanic recently informed me that I needed to replace my thermostat. We briefly met under the hood of my truck and he assured me that the repair was similar to other thermostat replacements I had done (once) some twenty years past. I asked that he confirm the location of the T-stat, and he pointed out the most logical area at the engine block side of the upper radiator hose. Now empowered with knowledge and some self confidence, I tore into my truck only to find no T-stat at that location. After serveral hours on the net, I found a contradiction of results. 60% say on the upper hose and 40% say on the lower hose. The latter of the two requires a great deal more labor and disassembly of the cooling system, removal of drive belts and at the least the removal of the power steering pump to access the water outlet/thermostat housing. I hope you understand my hesitance in jumping back into the fix without some verification first.
Questa è una buona domanda?
1 Commento
Excellent job, who would have thought :-) now all you have to do is convert your comment to an answer and accept it. This way we know your case is closed. Great job in getting it done.
da oldturkey03
