Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
2375 Domande Visualizza tutte
Domanda Chiusa
The iPhone 4 shutt down alone please who gotta help me
i was watching youtube in i phone4 then he shut down by his self
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
bader, did you try to reset your iPhone?
Press and hold the Sleep/Wake button until the red slider appears.
Drag the slider.
Press and hold the Sleep/Wake button again until the Apple logo appears.
Punteggio 2
8 Commenti:
'THIS WILL COMPLETELY ERASE YOUR DATA ON YOUR PHONE'...that's incorrect, a hard reset does not completely erase all of your data. Only a complete reset through the 'Settings" menu would completely erase all of your data. Your first recommendation is just a simple reboot, there's no such reset the way you have described it.
da
You are absolutely right. I edited the answer accordingly, however at least the reset worked. Thank you for pointing that out to me. I think a complete restore through itunes would accomplish the same thing.
da
No problem. I'll remove the down-tick now that the answer was edited. +1
da
I appreciate that. Long shifts in the ER lead me to hallucinations :-)
da
thnks so much for ur answer it's work now i have question the flash player don't work what can do
da
Mostra altri 3 commenti
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 830
