Salta al contenuto principale
Il top di gamma Huawei nel 2016. Basato su un case unibody, ha una doppia fotocamera posteriore sviluppata in collaborazione con Leica. Può avere 32 o 64 GB di memoria interna e sei diverse finiture esterne. I numeri di modello sono EVA-L29, EVA-L19 ed EVA-L09.
72 Domande Visualizza tutte
Can you replace the simcard reader on the P9?
Hello, so i bought a P9 and the woman said that it would not connect to the network, but that the phone still read the simcard.
But when i got the phone and tried it out the sim-reader did not work.
So my question is, can you desolder this and solder a new one on it? I have not seen any videos about it . Does anybody know a solution?
picture of the simreader on the motherboard:
https://d3nevzfk7ii3be.cloudfront.net/ig...
Thanks in advance!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
You would need a hot air rework station and relevant soldering tools to remove the sim / microSD reader combo and replace it.
It's fairly pricey to do if you don't have the tools and requires some experience to avoid damaging components around the reader.
Punteggio 3
3 Commenti:
Would one of these be good enough? What do you have to look after when buying one of these?
https://www.aliexpress.com/item/YIHUA-EU...
da
Second link seems good, has everything you need. Though you should use something to cover surrounding components to stop them from being heated. e.g kapton tape for example.
I recommend watching some videos on youtube on how to replace the sim reader using those kind of tools.
da
Aggiungi la tua risposta
Pieter sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 180
