Recovering data with broken system
Windows 8.1 won't boot on this device. I have some important files to recover from it. Bootable usb with linux doesn't help. Is there a way to get them back?
Questa è una buona domanda?
You can try using an external USB adapter for the drive and then connect it to a working computer to try to copy your data.
does it have hdd though?
HDD or SSD? both should work fine with a hard drive docking station. You can find them on amazon I'm sure, or just open up your desktop and connect with sata.
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 7
Tutti i Tempi: 383
6 Commenti
Do you have a working desktop PC? So you could test the disk.
da ULEES
i have but im not sure if it has internal hdd
da Tomasz Kowalski
How did it break? did you drop it? spill something on it?
da Aiden
i installed updates and the system crashed
da Tomasz Kowalski
Problem fixed: i booted the windows 8.1 usb drive, then launched cmd. Using it I managed to move all the files to the usb. However switching between the drives doesn't work without "cd /d c:\".
da Tomasz Kowalski
Mostra 1 altro commento
