Salta al contenuto principale
Rilasciato il 16 settembre 2016. Modelli 1660, 1774 e A1785. Disponibile come GSM o CDMA / 32, 128 o 256 GB / Rose gold, gold, silver, black e jet black.
1364 Domande Visualizza tutte
Where is the 4G Antenna
Hi,
Since doing a power jack replacement on an iPhone 7 Plus it has no signal, it recognizes the SIM but will not get signal anywhere. Can anyone tell me where the 4G antenna is please so I can look at replacing it.
Thanks
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
There is a 4G antenna next to the iPhone7 Plus speaker.
Punteggio 2
3 Commenti:
Hi, How sure are you this is for 4G as when going to purchase this part it seems to be advertised as the WiFi antenna. Regards, Greg
da
The Wi-Fi antenna uses a flex cable to plug into the board and is not this part.
Anyway, you should inspect the part that is shown in the image. Chances are it's either not plugged in or the cable has become damaged. Usually when you change a charging port assembly you may need to temporarily remove this antenna.
da
Hi guys, I have the exact same issue after replacing my power jack, Did you get it fixed?
da
So it's this cheeky little bastard that I'm missing on my refurb iPhone 7+. Who could've thought
Punteggio 0
Aggiungi la tua risposta
Greg Powell sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 22
Tutti i Tempi: 9,987
