When I listen to my earbuds I can only hear if I turn the volume up hi
I can’t hear anything from my earbuds unless I run up the volume high
Questa è una buona domanda?
there are plenty of reasons for muffled sound in earbuds,
-be sure to clean them out of wax, as earbuds easily buildup earwax, which will muffle the sound.
-volume setting problems. the iphones have volume limiters in their accessability settings. verify they are not set low.
-They could be blown. The speakers in them could have issues, but this usually results in either no sound, or crackling. rarely quiet.
-damaged filter. A filter in the bud circuits could be blown, or chipped, causing an improper frequency to come through.
- Poor blutooth signal. the blutooth may not be as strong as it should be, causing volume issues.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 24
Do the earbuds work properly with any other device? Have you tried them on a laptop or another phone? Have you tried other earbuds or speakers? This should tell you if it's the earbuds or your phone that are the problem.
da Jerry F Nerviano
