Salta al contenuto principale
27" display with 2560 x 1440 pixels resolution Thunderbolt & MagSafe cable attachments
160 Domande Visualizza tutte
Magsafe led blinking on Thunderbolt display
Hi all,
My Macbook Air no longer charges when connected to my Thunderbolt display.
The led on the magsafe connector is blinking fast (green).
Question: what could be the problem?
Tried: cleaning the connectors / reset PRAM / reset SMC / disconnect power for long period (hours).
All the best from Holland,
Pieter
Questa è una buona domanda?
Punteggio 0
2 Commenti
Does a regular MagSafe charger work? Solid Green and when battery is low Amber.
da
Hi Dan, charging works when I use another Magsafe charger (Solid Green and when battery is low Amber)
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
We don't have a cord or power supply replacement guide. If the cord looks OK I would suspect the power supply is having problems. Here is the IFIXIT teardown which can help guide you Apple Thunderbolt Display Teardown and here's a good guide which willl get you in Sostituzione del filtro EMI su un display Apple Thunderbolt
Immagine Apple Thunderbolt Display
Guida
Difficoltà:
Moderato
Immagine Apple Thunderbolt Display Filtro EMI
Guida
Difficoltà:
Moderato
25 - 35 minutes
Punteggio 2
3 Commenti:
Hi Dan,
Many thanks for your answers. The cord looks OK.
The screen is fully functional. Would't there be more problems if the power supply is failing?
All the best,
Pieter
da
The power supply offers multiple power feeds so the MagSafe feed have a problem unlike the other feeds.
da
Hi Pieter,
I'm having a similar problem. Did you ever replace the power supply and did that fix your problem?
Thanks,
Viktor
da
Aggiungi la tua risposta
Pieter sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 994
