Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3530 Domande Visualizza tutte
after replacing the screen it worked but by closing the device it dies
so i replaced the screen with carefull and everything is working when i turn on my phone but when i try to close it it shut down everytime when its opened and lifted i can get exsess to the device where is the problem ......
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Usually this is caused by either a faulty screen, forcing the screen in a iPhone frame that is dented and pushing against the frame, or damaged home button / front camera ribbon flex cables.
Punteggio 2
I was replacing the LCD/camera/mic/speaker on a IPhone SE and the screen I'm using was bought off of Ebay and I have bought this exact screen and replace on another phone so I went along by carefully removing the broke screen and I plugged in the 3 ribbon cables for the screen and turned on the phone to check if everything was working and it was so I put the 4 screws into place tighten them down and I'm using the original home button with touch id, I plug the home button in and put that little clip over the plug and everything is still working but the touch id and I knew that the phone just needed to be restarted then it would work then as I'm clipping the screen back down the screen goes black and won't show any life so now I'm thinking to myself "WTF" so I go back and unplug the button and go to unplug the battery and plug everything back in and boom working again as I start to clip the screen back down it does the same thing and this repeats multiple times till I got super upset with it I put the old broken screen back on and everything works but the screen is broke
Punteggio 0
Aggiungi la tua risposta
max lange sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 39
