Salta al contenuto principale
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
781 Domande Visualizza tutte
How to install ps3 firmware from pc to ps3 hard drive directly
The real problem is with the bluetooth/WiFi card. It wasn't working before the system update. and it's soldered to the ps3 board "hard to be replaced " .
i search for any other way to complete the update without replace the chip
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Did you find a solution bro?
Punteggio 0
you can remove the hard drive and buy a sata to usb adaptor
and connect the hard drive to the laptop or pc and transfer the file and reconnect it to the ps3 or you can just put the file on a usb stick and plug it into the ps3 and transfer files for update
Punteggio 0
1 Commento:
does this still work and do i do PS3 \UPDATE \.PUP
or just put .pup straight into hdd
da
Aggiungi la tua risposta
mohamad sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 31
Tutti i Tempi: 3,355
