Salta al contenuto principale
LG's flagship smartphone, with a unique slide-out battery and detachable I/O module supporting multiple hardware expansion options. Released in April 2016.
power button pin out?
i cant find the pin out for the Power button flex. can someone highlight the two leads for the power button? im trying to diagnose a phone that wont turn on, but i dont have a spare button to compare it to.
thankyou.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Risposta Più Utile
xxx
xxx
x2x
1 + 2 =power
Punteggio 3
1 Commento:
is there ANY chance you know what "O" does in the below example? the pin on my board that lines up with O is missing, I'm thinking to use a donor board and get someone to re-solder it on...
x
xxx
xxx
xxO
da
the top pin and the bottom middle pin… use the volt meter on continuity mode and click the button until it beeps while you are pressing it !!! BOOYAH
Punteggio 0
You are god
No good
Just god
Tnx alot
Punteggio 0
Aggiungi la tua risposta
Scott sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,454
