Salta al contenuto principale
HD action camera with touchscreen LCD, released October 5, 2014.
My GoPro will not charge/turn on?
I have tried 2 different batteries, a new usb cable and it will not turn on at all.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
@cperetin check the charging port to make sure it is not corroded, has any broken or bend pins or is otherwise damaged. If that does not work you will need to have to take it apart and check the connection of the port to the board. Use these guides GoPro Hero4 Silver to work on your GoPro
Punteggio 2
Aggiungi la tua risposta
Christine Peretin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 22
Tutti i Tempi: 969
